TipSwitching among open documents is a breeze with the Document Bar.
Font format
The font format controls the basic look and feel of document text. It includes the following options:
Font
A font (or a typeface) is a set of glyphs that share common design features, such as the width of the thick and thin strokes that compose the characters and the presence or absence of serifs.
Below are examples of fonts:
Typefaces
Size
Font sizes are specified in points (1 pt = 1/72 inch):
Font sizes
Font sizes can include half a point. For example: 8.5, or 12.5
Font color
Document text can be displayed in various colors:
Font colors
The "Auto" font color is printed as black on paper. On screen it also shows as black in most cases. But the "Auto" font color might show as a different color depending on the Display properties of Windows and the current color scheme of Atlantis.
Highlight
Highlight adds a background color to a text fragment:
Highlight text
Underline style & color
Atlantis can display lines of various shapes, thickness, and color below the text:
Underline
When the "Auto" underline color is selected, the actual color of the underline matches the font color of the text. For example, if the text is formatted with the blue font color, the underline will be blue, too.
Bold
Bold makes a text become darker and a little bigger:
Bold
Italic
Italic texts normally slant slightly to the right:
Italic
Strikeout
When a character is formatted with "strikeout", Atlantis draws a horizontal line through this character:
Strikeout
Double strikeout
Same as "strikeout" but a double line is drawn:
Double strikeout
Superscript
Characters formatted with "superscript", display as an upper index of mathematical formulas:
Superscript
Subscript
Characters formatted with "subscript", display as a lower index of mathematical or chemical formulas:
Subscript
Small caps
A lowercase letter formatted with "small caps", displays as a capital letter of a reduced size:
Small caps
Small caps formatting does not affect numbers, punctuation, nonalphabetic characters, or uppercase letters.
All caps
A letter formatted with "all caps", always displays in uppercase.
Shadow
Adds a shadow to a character:
Font shadow
Outline
When a character is formatted with "outline", Atlantis displays the inner and outer borders of this character:
Outlined font
Emboss
When a character is formatted with "emboss", Atlantis displays it as if it is raised off the page in relief:
Embossed font
Engrave
When a character is formatted with "engrave", Atlantis displays it as if it is imprinted or pressed into the page:
Engraved font
Scale
Stretches or compresses text horizontally:
Font scale
Spacing
Decreases or increases intercharacter spacing:
Character spacing
Location
Displays text with a vertical offset:
Vertical location
Kerning
Some fonts contain information about pairs of characters which could be placed more tightly or spaced more evenly within a paragraph line to produce more even and natural appearance of text.
A minimal font size of characters to apply kerning to is specified. As a rule, kerning is used for larger font sizes.
Kerning
