TipYou can convert multiple documents to a different format with the Batch conversion tool.
Hot keys. Font formatting
Command Hot key
Show the "Font Format" dialog CtrlD
Open the "Font" combo box CtrlShiftF
Open the "Font size" combo box CtrlShiftP
Bold CtrlB
Italic CtrlI
Underline CtrlU
Word underline CtrlShiftW
Strike CtrlKS This is a compound hot key.
Compound hot keys are multistep hot keys.
Let's take CtrlShiftKU as an example. You must:
1. Hold the Ctrl and Shift keys pressed,
2. Press and release the K key,
3. Press and release the U key,
4. Finally release the Ctrl and Shift keys.
Superscript CtrlShiftPlus
Subscript Ctrl=
Shrink font size Ctrl[
Grow font size Ctrl]
Shrink font size to the nearest predefined CtrlShift<
Grow font size to the nearest predefined CtrlShift>
Proportional font scaling AltShiftS
Reset font format CtrlSpace
Decrease intercharacter spacing CtrlAlt⇐
Increase intercharacter spacing CtrlAlt⇒
Offset up CtrlAlt⇑
Offset down CtrlAlt⇓
