TipShift+F3 converts a selection of text to uppercase.
Paragraph borders & shading
To draw your readers' attention to certain paragraphs or just set them apart from the other fragments of your document, you can apply paragraph borders and shading to them. On the illustration below, paragraph borders and shading are used for emphasizing a heading:
Heading with borders
Borders and shading can be applied to individual paragraphs or a group of paragraphs. To apply borders and shanding to a paragraph, just click it in the document. Otherwise select the required paragraphs. Then click the Paragraph borders & shading Button image button of the Paragraph toolbar The 'Paragraph' toolbar .
In the "Paragraph Borders & Shading" dialog, choose the desired border width and color:
Choosing border width and color
then apply desired borders:
Applying paragraph borders
Note that the paragraph's properties can include up to 5 borders. In addition to the standard borders – left, top, right, and bottom – displaying on the corresponding sides of a paragraph:
Standard border types
you can also specify the "inside" border:
The 'Inside' border
When you have a group of consecutive paragraphs with identical border formatting and paragraph indents, their left, top, right, and bottom borders are displayed around the entire group of paragraphs, while the "inside" border is displayed between the paragraphs of this group:
Borders between paragraphs
To specify the distance between the paragraph's text and its borders, use the "Border Spacing..." button in the "Paragraph Borders & Shading" dialog:
Border spacing
To change shading of the selected paragraphs, use the corresponding box at the bottom of the "Paragraph Borders & Shading" dialog:
Shading
You don't necessarily have to apply both borders and shading. If you like, you can specify only borders, or only shading.
Note that paragraph borders and shading can also be included in a paragraph style:
