TipThe Control Board of Atlantis brings together various tools and commands for document design.
AtlanTips
Resizing the Control Board and the Document Bar
The Atlantis Control Board can be resized with the mouse if you
  • place the mouse pointer over its right-hand edge,
  • wait till the mouse pointer turns into a double-arrow,
  • press and hold the mouse left button,
  • drag the mouse pointer horizontally,
  • release the mouse button when the desired width is achieved (or press the Esc key to cancel resizing).
Resizing Document Bar
The Atlantis Document Bar can be resized in the same way by capturing the edge which is closer to the document window.
