TipYou can reopen a recent document by choosing it from the "File | Recent Documents" menu. Click for details...
Command-line parameters
You can pass additional instructions to Atlantis when it is launched by adding parameters to its command-line. For example, if you add the "-fs" parameter to the command-line of the Desktop shortcut of Atlantis:
A command-line parameter
it will always launch Atlantis in the Full Screen mode.
You can launch custom command-lines by pressing Windows KeyR, through batch files, or using corresponding features of file managers or other applications.
The command-line of Atlantis can contain document filenames to be opened by Atlantis, and additional switches. For example, the following command-line instructs Atlantis to open three document files:
awp.exe C:\Doc01.rtf D:\Doc02.doc E:\Doc03.docx
The command-line switches must be preceded by a dash "-" or a slash "/".
The following table lists the switches that can be used in the command-line of Atlantis:
Switch Description Sample command-line
p Instructs Atlantis to print the document specified in the command-line, and shut down. Before printing the document, Atlantis displays the "Print" dialog to choose a printer and related options. awp.exe -p C:\Doc01.rtf
npd Used in conjunction with the p switch. Instructs Atlantis to print the document from the command-line to the default printer silently (without displaying the "Print" dialog). awp.exe -p -npd C:\Doc01.rtf
pt Instructs Atlantis to print the document from the command-line to the specified printer silently (without displaying the "Print" dialog). awp.exe -pt C:\Doc01.rtf "hp deskjet 656c series"
n Atlantis does not create a new document at startup. awp.exe -n
r The main window of Atlantis is not "maximized" at startup. awp.exe -r
m The main window of Atlantis is "maximized" at startup. awp.exe -m
fs Atlantis automatically activates the Full Screen mode. awp.exe -fs
dls Atlantis does not retrieve settings from the INI file but uses the default "factory" settings instead. awp.exe -dls
(use this command-line to switch to the "factory" settings)
dss Atlantis does not save settings on close. awp.exe -dss
sfn Instructs Atlantis to use the INI file from the command-line. awp.exe -sfn "D:\Custom.ini"
Note that the filenames in the command-line that include spaces, must be enclosed within double quotes. For example, to open the document file named "My Document.rtf", use the following command-line:
awp.exe "My Document.rtf"
