TipCtrl+Backspace deletes the word found before the current cursor position.
The Full Screen mode
The Full Screen mode of Atlantis is a special distraction-free view with very few, if any, GUI components of the Atlantis window displayed. When this mode is on, the Atlantis window covers the entire screen providing maximum space for document content.
To activate the Full Screen mode, choose the "View | Full Screen" menu command, or click the Full Screen Button image button of the View toolbar The 'View' toolbar , or press F9. To exit the Full Screen mode, press F9 again, or press Esc.
On the "View" tab of the "Tools | Options..." dialog of Atlantis you can choose which GUI components should be available under the Full Screen mode.
By default, the main menu and toolbars of Atlantis are not displayed under the Full Screen mode. But if you hover the mouse pointer close to the screen top (in case with top-aligned toolbars) or the screen side (in case with left- or right-aligned toolbars), both the main menu and the toolbars become temporarily available. This way, you can access various commands of Atlantis using the mouse even under the Full Screen mode.
