TipCtrl+Backspace deletes the word found before the current cursor position.
Hot keys. Cursor movement
Command Hot key
Move the cursor left one character ⇐
Move the cursor right one character ⇒
Move the cursor left one word Ctrl⇐
Move the cursor right one word Ctrl⇒
Move the cursor up one line ⇑
Move the cursor down one line ⇓
Move the cursor up one paragraph Ctrl⇑
Move the cursor down one paragraph Ctrl⇓
Move the cursor to the start of the line Home
Move the cursor to the end of the line End
Move the cursor to the top of the document CtrlHome
Move the cursor to the end of the document CtrlEnd
Scroll the document one page up PgUp
Scroll the document one page down PgDn
Move the cursor to the previous object CtrlPgUp
Move the cursor to the next object CtrlPgDn
