TipCtrl+End moves the cursor to the end of the document.
Special symbols
Any document in Atlantis can contain various special characters and objects. Some of them never get printed on paper and by default are not visible in the document window.
The "Special symbols" mode of Atlantis makes it easier to identify the special characters and objects contained by the document. To activate this mode, click the Special symbols Button image button of the View toolbar The 'View' toolbar , or choose the "View | Special Symbols" menu command, or press CtrlShift8. When this mode is on, Atlantis displays special symbols for the special characters and objects contained by the document.
The following table lists all the special symbols of Atlantis, the corresponding special characters and objects, and the hot keys that can be used to insert those characters and objects to a document:
Special symbol Special character/object Hot key
The "end of paragraph" mark
Terminates each paragraph.
Enter
¤ The "end of cell" mark
Terminates each table cell.
¤ The "end of row" mark
Terminates each table row.
The 'line break' special symbol Line break
Starts a new paragraph line without starting a new paragraph.
ShiftEnter
·····Page Break····· Page break
Creates a manual page break.
CtrlEnter
·····Column Break····· Column break
Starts a new column in a multicolumn section.
CtrlShiftEnter
:::::Section Break::::: Section break
Starts a new document section.
The 'tab' special symbol Tab character
Tab characters are used for lining up text or numbers in tables, or for aligning text to a specific location in the document.
Tab
° Nonbreaking space
Prevents an automatic line break (line wrap) at its position.
CtrlShiftSpace
— Nonbreaking hyphen
CtrlShiftHyphen
The 'optional hyphen' special symbol Optional hyphen
Indicates a position within a word where an automatic hyphen can be placed.
AltShiftHyphen
The 'bookmark delimiter' special symbol Bookmark delimiters
Indicates bookmarked locations or text fragments in a document.
AltShiftB
The 'automatic note reference' special symbol Automatic note reference
When documents include automatic footnote or endnote reference marks, they are highlighted with a dotted frame.
Note that custom note reference marks are not framed in such a way.
AltShiftF
or
AltShiftD
The 'index entry' special symbol Index entry
Indicates index entries used to generate the index.
AltShiftX
Tip:
  • Some special characters can be inserted to a document through the drop-down menu of the Insert symbol Button image button of the Insert toolbar The 'Insert' toolbar .
