TipAtlantis can display your writing time & speed on the status bar.
Click & Type
Note: this article describes a feature unavailable in the current version of Atlantis Word Processor.
With the "Click & Type" feature you can quickly start typing text at any open area of a document. Just double-click the desired point, and type your text.
When your mouse pointer is over a blank area of the document, the following mouse pointers can be displayed:
Click and type mouse pointers
The shape of the mouse pointer indicates which alignment will be used for your new text.
After double-clicking the desired point, you can start typing text. You can undo this typing as any other operation.
The "Click & Type" feature can be enabled or disabled through the Click & Type option (choose the Tools | Options... menu command, click the Edit tab).
Note. The "Click & Type" feature is not available in paragraphs belonging to bulleted or numbered lists.
