TipYou can choose document templates to be used for creating new documents by clicking the "File | New | Formats & Templates..." menu command. Click for details...
Paragraph formatting
You can apply various paragraph formatting characteristics to your document text.
Before applying a new paragraph format to a text fragment, you should first select that fragment in the document. Then you can change individual paragraph formatting characteristics of the selected text by clicking the corresponding toolbar buttons, pressing the associated hot keys, or through the main menu of Atlantis.
Note: If no text selected in the document, all the paragraph formatting commands apply to the current paragraph (the paragraph containing the cursor).
Tip:
  • You can use the Format Brush to apply paragraph formatting.
