TipYou can use the "Edit | Go To..." menu command, or press Ctrl+G, or double-click any of the 2 leftmost status bar sections to call the "Go To" dialog. Use it for quick navigation to any specific page, section, paragraph, bookmark, footnote, endnote, or table.
Hot keys. View
Command Hot key
Show / hide special symbols CtrlShift8
Open the "Zoom" combo box CtrlKZ This is a compound hot key.
Compound hot keys are multistep hot keys.
Let's take CtrlShiftKU as an example. You must:
1. Hold the Ctrl and Shift keys pressed,
2. Press and release the K key,
3. Press and release the U key,
4. Finally release the Ctrl and Shift keys.
Center document window horizontally Alt5 (NUMPAD)
(Num Lock must be toggled off)
Zoom - "Page width" CtrlShiftKP This is a compound hot key.
Zoom - "Text width" CtrlShiftKT This is a compound hot key.
Zoom - "Whole pages" CtrlShiftK1 This is a compound hot key.
Zoom - "Two pages" CtrlShiftK2 This is a compound hot key.
Zoom - 100% CtrlShiftK0 This is a compound hot key.
Decrease zoom factor (-10%) CtrlMinus (NUMPAD)
or
CtrlAltShift⇓
Increase zoom factor (+10%) CtrlPlus (NUMPAD)
or
CtrlAltShift⇑
Show / hide the Clippy Bank F8
Toogle the Full Screen mode F9
Tip:
  • The Esc key cancels the "mouse modes" of Atlantis (Full Screen, Easy Hand, Format Brush, etc).
