TipYou can automate your search operations with the batch find & replace tool.
Examples of regular expressions: searching for parentheses
The following regular expressions can be used to search documents for parentheses.
Search for text in parentheses
Paste the following regular expression to the "Find what" box of the Find/Replace panel of the Control Board to match any text in parentheses in your document:
\([!()]{0,}\)
For example, this expression would match the text highlighted below:
Marilyn Monroe (born Norma Jeane Mortenson) was as iconic as her life was tragic.
Search for text in parentheses (not including the parentheses)
\(|[!()]{0,}|\)
For example:
Replace parentheses with square brackets
With the following "find what" pattern:
\(([!()]{0,})\)
and the following "replace with" pattern:
[\1]
you could replace parentheses:
The study participants showed no improvement in cholesterol levels (McLellan and Frost, 2012).
with square brackets:
The study participants showed no improvement in cholesterol levels [McLellan and Frost, 2012].
Replace parentheses with figure brackets
\(([!()]{0,})\)
{\1}
with figure brackets:
The study participants showed no improvement in cholesterol levels {McLellan and Frost, 2012}.
Replace parentheses with commas
(^w)\(([!()]{0,})\)(^w)
,\1\2,\3
with commas:
Marilyn Monroe, born Norma Jeane Mortenson, was as iconic as her life was tragic.
Replace parentheses with long dashes
\1— \2 —\3
with long dashes:
Marilyn Monroeborn Norma Jeane Mortensonwas as iconic as her life was tragic.
Search for nested (double) parentheses
\([!()]{0,}\([!()]{0,}\)[!()]{0,}\)
For example:
Australia's Parliament House (architects Mitchell/Giurgola & Thorp (New York)) opened on 9 May 1988.
Search for text inside nested (interior) parentheses
\([!()]{0,}\(|[!()]{0,}|\)[!()]{0,}\)
For example:
Replace nested (interior) parentheses with square brackets
(\([!()]{0,})\(([!()]{0,})\)([!()]{0,}\))
\1[\2]\3
you could replace nested (interior) parentheses:
Australia's Parliament House (architects Mitchell/Giurgola & Thorp [New York]) opened on 9 May 1988.
Replace nested (interior) parentheses with long dashes
(\([!()]{0,}^w)\(([!()]{0,})\)(^w[!()]{0,}\))
\1— \2 —\3
Fauna populations declined in industrial areas (pollinators in the study (bees and hummingbirds) were tracked separately).
with long dashes:
Fauna populations declined in industrial areas (pollinators in the studybees and hummingbirds were tracked separately).
Note: Before searching with a regular expression, make sure that the "Use wildcards" option is enabled in the Find/Replace panel of the Control Board:
The 'Use wildcards' option
or in the Find/Replace dialog:
Tip:
  • You can add your commonly used regular expressions to the saved searches.
