TipYou can duplicate a selection of text or picture by pressing Ctrl+K, C. The duplicate item is automatically inserted next to the source selection.
Hot keys. Edit
Command Hot key
Insert new paragraph Enter
Insert line break ShiftEnter
Insert page break CtrlEnter
Insert column break CtrlShiftEnter
Insert tab Tab
Insert nonbreaking space (U+00A0) CtrlShiftSpace
Insert nonbreaking hyphen (U+2011) CtrlShiftHyphen
Insert optional hyphen (U+00AD) AltShiftHyphen
Insert short dash (U+2013) CtrlHyphen
Insert long dash (U+2014) CtrlAltHyphen
Delete selection or character after cursor Del
Delete character before cursor Backspace
Delete left word CtrlBackspace
Delete right word CtrlDel
Delete current line CtrlKY This is a compound hot key.
Compound hot keys are multistep hot keys.
Let's take CtrlShiftKU as an example. You must:
1. Hold the Ctrl and Shift keys pressed,
2. Press and release the K key,
3. Press and release the U key,
4. Finally release the Ctrl and Shift keys.
Delete to beginning of line CtrlKBackspace This is a compound hot key.
Delete to end of line CtrlKDel This is a compound hot key.
Copy CtrlC
or
CtrlIns
Paste CtrlV
or
ShiftIns
Paste as environment (paste as plain text) CtrlAltIns
Cut Ctrl+X
or
ShiftDel
Append to Clippy Bank CtrlF8
Cut to Clippy Bank AltShiftF*
Clear Clippy Bank CtrlAltF8
Paste from Clippy Bank ShiftF8
Duplicate selection CtrlKC This is a compound hot key.
Copy font format CtrlShiftC
Paste font format CtrlShiftV
Copy paragraph format AltShiftC
Paste paragraph format AltShiftV
Copy all formatting AltShiftKC This is a compound hot key.
Paste all formatting AltShiftKV This is a compound hot key.
Insert current date AltShiftD
Insert current time AltShiftT
Find CtrlF
Replace CtrlH
Find next F3
or
ShiftF5
Replace next CtrlShiftF5
Redo last Find / Replace operation CtrlAltShiftF5
Replace all next AltShiftF5
or
CtrlAltY
Go to CtrlG
New bookmark AltShiftB
Go to previous bookmark Ctrl\ (NUMPAD)
Go to next bookmark Ctrl* (NUMPAD)
Save selection as CtrlShiftF12
Save picture as graphic file CtrlAltShiftF12
Toggle Insert / Overwrite mode Ins
Select all CtrlA
Select current word CtrlKT This is a compound hot key.
Select current line CtrlKL This is a compound hot key.
Select current sentence CtrlKE This is a compound hot key.
Select current paragraph CtrlKP This is a compound hot key.
Select current page CtrlKG This is a compound hot key.
Select current section CtrlKI This is a compound hot key.
Invert selection CtrlKA This is a compound hot key.
Navigate among recent locations F5
Undo CtrlZ
or
AltBackspace
Redo CtrlY
or
CtrlShiftZ
or
AltShiftBackspace
Join paragraphs CtrlShiftU
Split paragraphs CtrlShiftKU This is a compound hot key.
Sort paragraphs (ascending order) CtrlShiftKA This is a compound hot key.
Sort paragraphs (descending order) CtrlShiftKZ This is a compound hot key.
Move the current paragraph or selection of paragraphs up AltShift⇑
Move the current paragraph or selection of paragraphs down AltShift⇓
Convert to uppercase ShiftF3
Convert to lowercase CtrlF3
Invert case CtrlShiftF3
Cycle through case AltShiftF3
Calculate Alt=
Insert a "Current Page Number" field AltShiftP
Update fields ShiftF9
Insert footnote with automatic reference mark CtrlAltF
Insert endnote with automatic reference mark CtrlAltD
