TipYou can reorder the structure of the active document using Drag & Drop in the Headings panel of the Control Board. Dragging the panel items up or down automatically moves the corresponding headings and their associated text up or down the document itself. Dragging in a horizontal direction promotes or demotes the corresponding heading(s) in the active document.
Privacy, Security & Safety
Atlantis Word Processor is designed with an emphasis on making document editing not only productive and comfortable, but also safe and secure. Below is a summary of how Atlantis treats your personal data, and how you can configure Atlantis to have a maximally secure and safe working environment.
Terminology
This article refers to the "user files" folder, which is the folder where Atlantis stores its user-specific files (the main configuration file "Atlantis.ini", document templates, spellcheck lexicons, Backup Files, the Clip Library, and more). The actual location of this folder is reported by the "User files location" box on the "Load\Save" tab of the "Tools | Options..." dialog of Atlantis.
The temporary folder is a location where Atlantis stores its various temporary files. Non-portable copies of Atlantis use the system Temp folder of the current Windows user for their temporary files. Portable copies of Atlantis store their temporary files in the "Temp" folder under their home folder.
Privacy
Atlantis is an offline word processor that does not require an Internet connection to function.1 It is not based on and does not use any cloud or remote services. To use Atlantis, you are not required to create an account with or login to any Web-based service.
Atlantis never sends any data (including your document files or their fragments) from your computer to any other device or server unless you explicitly instruct Atlantis to do so (for instance, by using the "Send by email" command of Atlantis, or the "Install as portable" command to create a portable clone of the current Atlantis copy on another drive).
Atlantis makes as few changes to the host system and leaves as few traces of its functioning as possible. Atlantis does not make changes to system files or system configuration (including file type associations). Non-portable copies of Atlantis make minimal changes to the Windows Registry2. Portable copies of Atlantis never make changes to the Windows Registry.
There are a number of program components that may require your attention concerning your privacy:
  • Over time, as you use Atlantis, it may record certain elements of your activity in various history lists. For instance, the "File | Recent Documents" menu lists the document files that you have recently opened. Or the Find/Replace tool of Atlantis keeps track of recently used search patterns. These history lists do not get cleared by default on program close. You may decide to set certain history lists to be automatically cleared on program close or disable the history lists altogether.
    When the Atlantis Clipboard history is enabled, Atlantis collects data placed onto the clipboard as separate clips in the temporary folder. These temporary clips get deleted on program close. You can disable the Clipboard history on the "Edit" tab of the "Tools | Options..." dialog.
  • The Clippy Bank of Atlantis may contain your sensitive information. You can press F8 in Atlantis to open the Clippy Bank and examine its contents. The Clippy Bank file does not get cleared on program close, so you may need to do so manually. The Clippy Bank file is named "Clippy Bank.rtf", and you may find it under the "user files" folder.
  • If the Power Type tool is enabled, the "Spellcheck" folder under the "user files" folder may contain files with the .cache extension. These files may contain words and entire phrases that you have typed in Atlantis over time. In addition to disabling the Power Type tool, you may also decide to delete its .cache files with the file manager.
  • Spellcheck user lexicons are stored as files with the .tlx file extension in the "Spellcheck" folder under the "user files" folder. If you have added words or phrases to the spellcheck user lexicons, you may wish to make sure these files do not contain any sensitive information.
  • The "User name" box on the "General" tab of the "Tools | Options..." dialog lists the name of the user of this copy of Atlantis. Atlantis may include this name in document files when saving documents or use it when updating fields. You may decide to change this "user name" for privacy reasons.
  • Atlantis removes its temporary files from the temporary folder on program close. But if Atlantis terminated abnormally for any reason, the temporary folder might contain files with your sensitive information. Running Atlantis again and closing it will remove the temporary files created by the earlier instances of Atlantis that were not closed correctly.
  • Atlantis may move files to the Windows Recycle Bin if the "Never move files to the Recycle Bin" option is not checked on the "General" tab of the "Tools | Options..." dialog.
  • The "Clip Library" folder under the "user files" folder may contain clips with your sensitive information if you ever added items to the Clip Library.
  • The "Favorites" folder under the "user files" folder may contain links to your documents exposing their file names if you ever added documents to the Favorites.
  • If you have ever created your own document templates or made changes to the standard document templates of Atlantis, the "Templates" folder under the "user files" folder may contain document files with your sensitive information.
  • The "Backup files" folder under the "user files" folder may contain old versions of your documents with sensitive information. To customize the Backup Files tool of Atlantis or revise the currently backed-up files, click the "Backup Files..." button on the "Load\Save" tab of the "Tools | Options..." dialog of Atlantis.
  • The "user files" folder may contain document files with your sensitive information if you ever instructed Atlantis to save your documents to this folder.
1 An Internet connection may be required to download certain optional components of Atlantis, update Atlantis, and access the online Help articles.
2 When creating a non-portable installation, the setup of Atlantis saves the install configuration (the destination folder and a few other options like "Create the Desktop shortcut" and "Install to all users") to the following Registry key:
HKEY_CURRENT_USER\Software\Atlantis Word Processor\Install. This information may be automatically used the next time you run the setup of Atlantis. To enable uninstallation of the non-portable copy of Atlantis, the setup also adds corresponding information to the following Registry key: HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Atlantis Word Processor.
Non-portable copies of Atlantis also add information to the HKEY_CURRENT_USER\Software\Classes section of the Windows Registry to allow correct association between Atlantis and its supported document types (the "HKEY_CURRENT_USER\Software\Classes\Atlantis.<document_type>" and "HKEY_CURRENT_USER\Software\Classes\.<file_extension>\OpenWithProgIds" Registry keys).
Security
The setup file of Atlantis does not install third-party applications or services. The Save as eBook tool of Atlantis may download the Amazon's kindlegen utility at the user's request. This utility is used by Atlantis exclusively to convert eBooks to the MOBI format. Atlantis may also download optional components (proofing tools, sound schemes, UI language packs, etc.) from its server if requested by the user.
The "user files" folder of a non-portable copy of Atlantis is by default located under the personal folder of the current Windows user, which is normally inaccessible to other users of this system. Note that Windows may automatically synchronize your personal folder (including the "user files" folder of Atlantis) to your cloud storage account. If you do not want your Atlantis files to be uploaded to a cloud storage, you can choose a different location for the "user files" of Atlantis on the "Load\Save" tab of the "Tools | Options..." dialog. Alternatively, you can convert your non-portable copy of Atlantis into a portable one (use the "Tools | Install as Portable..." menu command of Atlantis).
Portable copies of Atlantis store all their files under a folder chosen by the user, making it easier to secure and monitor its contents.
You may decide to encrypt documents containing sensitive information.
Atlantis never saves your passwords to encrypted documents on disk.
Safety
Atlantis offers multiple tools and options meant to prevent the loss of data, whether it is document files or configuration data.
The Backup Files tool can create automatic, regular backups of your documents as you work on them. Successive versions of each document are saved to a special backup folder. This way, you will always be able to go back to earlier versions of any document. You can choose where to backup documents to (for example, to a different drive or cloud storage).
Atlantis can create safe copies of documents in the temporary folder and autosave its settings at regular intervals against system failure and crashes.
To prevent accidental changes to certain document files, you can open them in Atlantis as read-only.
The entire Atlantis configuration can be easily backed up:
  • If you are using a non-portable copy of Atlantis, you can backup the Atlantis "user files" folder with the file manager. To restore a configuration backed-up in this way, you can simply copy the backed-up "user files" back to their original location with the file manager.
    An alternative way to backup the configuration of a non-portable copy of Atlantis is by creating its portable clone (use the "Tools | Install as Portable..." menu command). To restore a non-portable copy from its portable clone, run the portable copy and use its "Tools | Install as Non-Portable..." menu command.
  • If the copy of Atlantis is portable, you can simply backup the entire home folder of Atlantis with the file manager. If you need to restore your portable copy from the backup, just copy the backed-up home folder of Atlantis to the original or any other location.
